NAME | Description | Attributes | See Also
Syntax |
dn |
Default value |
Default behavior is not defined. |
Must be set |
Yes |
Is modifiable |
Yes |
Is multivalued |
No |
Requires restart |
No |
This property specifies the DN of the subtree represented by the data view.
This property takes a Distinguished Name (DN) value.
This property is used to configure the following features: jdbc-data-view, join-data-view, ldap-data-view, ldif-data-view.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWldap-proxy |
Stability Level |
Evolving |
dpconf(1M)
