NAME | Description | Attributes | See Also
Syntax |
string |
Default value |
none |
Must be set |
No |
Is modifiable |
Yes |
Is multivalued |
No |
Requires restart |
Yes |
This property specifies the upper bound of the distribution when distribution-algorithm(5dpconf) is lexicographic.
For example, consider a configuration with a first data view that handles [A-M] inclusive, and a second data view that handles [N-Z] inclusive. For the first data view, you set the lower bound to A, and the upper bound to M. For the second data view, you set the lower bound to N, and the upper bound to Z.
The default behavior for this property is as follows: No upper limit
This property is used to configure the following features: jdbc-data-view, join-data-view, ldap-data-view, ldif-data-view.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWldap-proxy |
Stability Level |
Evolving |
dpconf(1M)
