NAME | Description | Attributes | See Also
Syntax |
integer |
Default value |
none |
Must be set |
No |
Is modifiable |
Yes |
Is multivalued |
No |
Requires restart |
Yes |
This property specifies the upper bound of distribution when the distribution-algorithm(5dpconf) is numeric.
This property takes an integer.
The default behavior for this property is as follows: No upper limit
This property is used to configure the following features: jdbc-data-view, join-data-view, ldap-data-view, ldif-data-view.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWldap-proxy |
Stability Level |
Evolving |
dpconf(1M)
