NAME | Description | Attributes | See Also
Syntax |
string |
Default value |
Default behavior is not defined. |
Must be set |
Yes |
Is modifiable |
Yes |
Is multivalued |
No |
Requires restart |
No |
This property provides the column in the relational database table from which the LDAP attribute is obtained.
This property is used to configure the following features: jdbc-attr.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWldap-proxy |
Stability Level |
Evolving |
dpconf(1M)
