Name | Synopsis | Description | Examples | See Also
help [command_name]
command_name [--help | –?]
The help command displays a list of all the asadmin utility commands. Specify the command to display the usage information for that command. To display the man page of each command, use the syntax: asadmin command_name --help | -? or asadmin help command_name
The following is a list of all the asadmin utility commands:
registers the resource in the specified XML file
applies load balancer configuration changes to the load balancer
performs a backup on the domain
changes the administrator password
changes the master password
deletes tables in the HA database
configures an existing cluster to be High Availability
enables configuration of parameters related to session persistence
sets load balancing weights for clustered instances
sets the monitoring or maxhistory or attributes of a deployed webservice
copies an existing configuration to create a new configuration
adds the administered object with the specified JNDI name
creates a reference to an application
creates an audit module for the optional plugin module
adds the named authorized realm
creates a cluster
adds a connection pool with the specified connection pool name
registers the resource with the specified JNDI name
creates or modifies a security map for the named connector connection pool
creates a converged load balancer.
This command is available if you have installed Sun GlassFish Communications Server.
creates a converged load balancer configuration.
creates a converged load balancer reference.
registers the custom resource
creates a domain with the specified name
creates a new file user
creates tables in HA database that are used by HA cluster
creates a health-checker for a specified load balancer configuration
creates a load balancer
creates a configuration for the load balancer
add an existing cluster or server instance to an existing load balancer configuration
adds a new HTTP listener socket
adds the IIOP listener
creates an instance with the given name
registers the Javamail resource
registers the JDBC connection pool
registers the JDBC resource
creates a JMS host
registers the JMS resource
adds the named destination
registers the JNDI resource
creates the JVM options from the Java configuration or profiler elements
adds a lifecycle module
creates a new management rule
creates and registers a custom MBean
enables administrators to create the message-security-config and provider-config sub-elements for the security service in domain.xml
adds a new unbound node agent to a domain
creates a node agent and its associated directory structure
creates a password alias
registers the persistence resource
creates the profiler element
creates the resource adapter Java bean
creates a reference to a resource
configures the starting of a DAS or node agent on an unattended boot
creates the SIP listener.
creates the SSL element in the HTTP listener or IIOP listener
adds or updates one or more system properties of the domain, configuration, cluster, or server instance
creates the thread pool
creates transformation rule for a deployed web service
creates a trust configuration.
creates a trusted entity.
adds the named virtual server
removes the administered object with the specified JNDI name
removes a reference to an application
deletes the audit-module for the optional plugin module
removes the named authorized realm
deletes the specified converged load balancer
deletes the specified converged load balancer configuration.
deletes the specified converged load balancer reference.
deletes a cluster
deletes an existing configuration
removes the specified connection pool
removes the named resource connector
deletes the named security map
removes the custom resource
deletes the given domain
removes the named file user
deletes a health-checker for a specified load balancer configuration
deletes a load balancer
deletes a load balancer configuration
deletes the cluster or server instance from a load balancer configuration
removes the HTTP listener
removes the IIOP listener
deletes the instance that is not running
removes the Javamail resource
removes the JDBC connection pool
removes the JDBC resource
removes a JMS host
removes the JMS resource
destroys the named destination
removes the JNDI resource
deletes the JVM options from the Java configuration or profiler elements
removes the lifecycle module
deletes a specified management rule
deletes a custom MBean
enables administrators to delete a provider-config sub-element for the given message layer (message-security-config element of domain.xml)
removes a node agent from a domain
deletes the node agent and its associated directory structure
deletes a password alias
removes the persistence resource
deletes the profiler element
deletes the resource adapter Java bean
removes a reference to a resource
deletes the specified SIP listener.
deletes the ssl element from the HTTP listener or IIOP listener
removes one or more system properties of the domain, configuration, cluster, or server instance
deletes the thread pool
deletes the transformation rule of a given web service
deletes the trust configuration.
deletes the trusted entity
deletes the virtual server with the named virtual server ID
deploys a service assembly into the JBI environment
deploys the specified component
deploys the component that is in the specified directory, located in the domain
disables a sever or cluster managed by a load balancer
disables a sever or cluster managed by a converged load balancer
disables an application managed by a load balancer
stops the specified, deployed component
displays distribution of errors from instance server.log at module level
displays a summary list of severities and warnings
displays all the error messages for a given module at a given timestamp
enables a previously disabled sever or cluster managed by a converged load balancer
enables a previously-disabled application managed by a load balancer
enables a previously disabled sever or cluster managed by a load balancer
runs the specified, deployed component
exports the load balancer configuration to a file that can be used by the load balancer
marks a variable name for automatic export to the environment of subsequent commands in multimode
purges the messages in a JMS destination
immobilizes the named transaction service
generates reports that can help diagnose malfunctioning
shows the threads, classes and memory for a given target instance
gets the stubs of the client
gets the values of the monitorable or configurable attributes
provides information on the cluster health
displays a list of all the commands available in the command-line interface
installs a service engine or binding component into the JBI environment
installs a shared library into the JBI environment
checks to see if the JMS provider is running
lists all the administered objects
lists all application references in a cluster or unclustered server instance
lists the audit modules
lists the authorized realms
lists all backups and restores
lists the existing clusters
lists deployed components
lists all existing configurations
gets all the connection pools
gets all the connector resources
lists the security maps for the connector connection pool
lists all the converged load balancers.
lists all the converged load balancer configurations.
gets all the custom resources
lists the domains in the given domains directory
lists the file groups
lists the file users
lists load balancer configurations
lists load balancers
gets the HTTP listeners
gets the IIOP listeners
lists all the instances in the server
gets all the Javamail resources
gets all the JDBC resources
lists the binding components installed on the specified target
lists the service assemblies installed into the JBI environment
lists the service engines installed on the specified target
lists the JBI shared libraries that are installed into the JBI environment
lists the existing JMS hosts
gets all the JMS resources
gets all the named destinations
gets all the named destinations, browses and queries the JNDI tree
gets all the JNDI resources
gets the lifecycle modules
lists the management rules created using the create-management-rule command
lists the custom mbeans for a given target server instance
enables administrators to list all security message providers (provider-config sub-elements) for the given message layer (message-security-config element of domain.xml)
lists the node agents along with their status
lists all password aliases
gets all the persistence resources
returns list of configured web service registry access points
lists the resource adapters configured in an instance
lists the existing resource references
lists EJBs or Servlets in a deployed module or in a module of a deployed application
lists the system properties of the domain, configuration, cluster, or server instance
lists the thread pools
lists all of the timers owned by server instance(s)
lists all the transformation rules of a given webservice
lists all identity assertion trust configurations.
gets the virtual servers
lists the configurable elements and provides the fully qualified dotted names of the management components that have read-only or modifiable attributes
lets you log in to a domain
moves a timer when a server instance stops
displays monitoring data for commonly-used components
allows you to execute multiple commands while returning environment settings and remaining in the asadmin utility
tests if a connection pool is usable
publishes all the web service artifacts to registries
manually recovers pending transactions
returns an HA cluster to non-HA status
restores files from backup
rolls back the named transaction
sets the values of attributes. Set command can be used to modify default properties of a resource.
uploads the Data Centric Rule (DCR) file from the Domain Administration Server (DAS).
displays the status of the deployed component
shows detailed information about the specified binding component
shows detailed information about a specified service assembly
shows detailed information about the specified service engine
shows detailed information about a specified shared library
shuts down a service engine or a binding component on the specified target
shuts down a JBI service assembly on the specified target
starts the domains in the specified domains directory
provides the complete callflow/path of a request
starts a cluster
starts the bundled Java DB database
starts the given domain
starts a server instance
starts a service engine or a binding component on the specified target
starts a service assembly on the specified target
starts a node agent
stops the domains in the specified domains directory
disables collection of callflow information of a request
stops a cluster
stops the bundled Java DB database
stops the given domain
stops a server instance
stops a service engine or a binding component on the specified target
stops a service assembly on the specified target
stops a node agent
undeploys a service assembly on the specified target
removes a component in the domain
uninstalls a service engine or binding component on the specified target
uninstalls a shared library on the specified target
unpublishes the web service artifacts from the registries
removes one or more variables from the multimode environment
removes the Data Centric Rule (DCR) file from the Domain Administration Server (DAS).
updates a current file user as specified
updates a password alias
upgrades a service engine or binding component
verifies the content of the domain.xml
displays the version information
The following commands are deprecated:
display-license
install-license
restart-instance
shutdown
create-acl
delete-acl
list-acls
start-appserv
stop-appserv
asadmin> help asadmin> create-domain --help |
Where: create-domain is the command you wish to view the usage for.
