Name | Synopsis | Description | Options | Operands | Examples | Exit Status | See Also
create-persistence-resource
[--terse={true|false}][ --echo={true|false} ]
[ --interactive={true|false} ] [ --host host]
[--port port] [--secure| -s ] [ --user admin_user]
[--passwordfile filename] [--help]
[ --enabled =true]
[--target target] [--jdbcjndiname jndi_name
| --connectionpoolid id] [--factoryclass classname]
[--description text] [--property (name=value)[:name=value]*]
jndi_name
The create-persistence-resource command registers a persistence resource. This command is supported in remote mode only.
The options --jdbcjndiname and --connectionpoolid are mutually exclusive; only one should be used.
Indicates that any output data must be very concise, typically avoiding human-friendly sentences and favoring well-formatted data for consumption by a script. Default is false.
Setting to true will echo the command line statement on the standard output. Default is false.
If set to true (default), only the required password options are prompted.
The machine name where the domain administration server is running. The default value is localhost.
The HTTP/S port for administration. This is the port to which you should point your browser in order to manage the domain. For example, http://localhost:4848.
The default port number is 4848.
If set to true, uses SSL/TLS to communicate with the domain administration server.
The authorized domain administration server administrative username.
If you have authenticated to a domain using the asadmin login command, then you need not specify the --user option on subsequent operations to this particular domain.
The --passwordfile option specifies the name, including the full path, of a file containing the password entries in a specific format. The entry for the password must have the AS_ADMIN_ prefix followed by the password name in uppercase letters.
For example, to specify the domain administration server password, use an entry with the following format: AS_ADMIN_PASSWORD=password, where password is the actual administrator password. Other passwords that can be specified include AS_ADMIN_MAPPEDPASSWORD, AS_ADMIN_USERPASSWORD, and AS_ADMIN_ALIASPASSWORD.
All remote commands must specify the admin password to authenticate to the domain administration server, either through --passwordfile or asadmin login, or interactively on the command prompt. The asadmin login command can be used only to specify the admin password. For other passwords, that must be specified for remote commands, use the --passwordfile or enter them at the command prompt.
If you have authenticated to a domain using the asadmin login command, then you need not specify the admin password through the --passwordfile option on subsequent operations to this particular domain. However, this is applicable only to AS_ADMIN_PASSWORD option. You will still need to provide the other passwords, for example, AS_ADMIN_USERPASSWORD, as and when required by individual commands, such as update-file-user.
For security reasons, passwords specified as an environment variable will not be read by asadmin.
The default value for AS_ADMIN_MASTERPASSWORD is changeit.
Displays the help text for the command.
Determines whether the resource is enabled at runtime.
Specifies the target for which you are creating a persistence resource. Valid targets are:
server- Specifies the default server instance as the target. server is the name of the default server instance and is the default value.
domain- Specifies a certain domain as the target.
cluster_name- Specifies a certain cluster as the target.
instance_name- Specifies a certain server instance as the target.
This option is valid only in domains that are configured to support clusters
Specifies the JDBC resource with which database connections are obtained. It must be the name of an existing JDBC resource.
This option and the option ---jdbcjndiname are mutually exclusive. If ---connectionpoolid is specified, then a jdbc resource will be created behind the scenes with 'PM' suffixed to the persistence resource name. See example.
Deprecated, and not needed for the default CMP implementation. Specifies the class that creates the persistence manager instance.
Specifies a text description of the persistence resource.
Specifies optional name/value pairs for configuring the persistence resource.
asadmin> create-persistence-resource --user admin --passwordfile passwords.txt --jdbcjndiname jdbc/sample sample_persistence_resource Command create-persistence-resource executed successfully |
asadmin> create-persistence-resource --user admin --passwordfile passwords.txt --connectionpoolid testPool testPersistence Command create-persistence-resource executed successfully |
This command creates a jdbc resource with the name testPersistencePM referencing testPool. When you delete the persistence resource, the jdbc resource created by this command is also removed.
