NAME | Description | Attributes | See Also
 Syntax  |
 duration  |
 Default value  |
 10000  |
 Must be set  |
 No  |
 Is modifiable  |
 Yes  |
 Is multivalued  |
 No  |
 Requires restart  |
 No  |
This property specifies the maximum length of time that a connection between Directory Proxy Server and a data source is attempted before the connection attempt fails.
The duration is expressed in milliseconds.
This property is used to configure the following features: ldap-data-source.
 ATTRIBUTE TYPE  |
 ATTRIBUTE VALUE  |
 Availability  |
 SUNWldap-proxy  |
 Stability Level  |
 Evolving  |
dpconf(1M)
