NAME | Description | Attributes | See Also
Syntax |
duration |
Default value |
3000 |
Must be set |
No |
Is modifiable |
Yes |
Is multivalued |
No |
Requires restart |
No |
This property specifies the maximum length of time that Directory Proxy Server waits for a connection to an LDAP server to become available if a connection pool is empty when a request is made.
The duration is expressed in milliseconds.
The value of this property must be at least 1.
This property is used to configure the following features: server.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWldap-proxy |
Stability Level |
Evolving |
dpconf(1M)
