NAME | Description | Attributes | See Also
Syntax |
enumeration |
Default value |
automatic |
Must be set |
No |
Is modifiable |
Yes |
Is multivalued |
No |
Requires restart |
No |
This property is a flag that indicates whether Directory Proxy Server automatically routes requests, or whether Directory Proxy Server relies on manual routing configuration.
This property can take the following values in addition to the default.
Directory Proxy Server automatically routes requests and ignores data view exclusion bases and alternate search bases.
Directory Proxy Server automatically routes requests but will take into consideration data view exclusion bases if present.
Directory Proxy Server does not automatically route requests. Instead, Directory Proxy Server routes requests according to the exclusion bases and alternate search bases specified in the data views.
This property is used to configure the following features: server.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWldap-proxy |
Stability Level |
Evolving |
dpconf(1M)
