NAME | Description | Attributes | See Also
Syntax |
enumeration |
Default value |
none |
Must be set |
No |
Is modifiable |
Yes |
Is multivalued |
No |
Requires restart |
Yes |
This property specifies the built-in algorithm used to distribute operations to data views that have the same base DN.
This property can take the following values in addition to the default.
Requests are distributed to data views based on the match between the parameters of the requests and one or more patterns.
Requests are distributed to data views based on the lexicographic value of the RDN specified in the request. Lexicographic bounds are taken from the value of the first RDN beneath the base DN of the data view.
Requests are distributed to data views based on the numeric value of the RDN specified in the request. The numeric value is taken from the value of the first RDN beneath the base DN of the data view.
Requests are distributed to data views based on the role of the data view in replication. The algorithm forces all write operations to be sent to all data sources in the data source pool, and all read operations to be sent to a single data source.
The default behavior for this property is as follows: No distribution algorithm is enabled
This property is used to configure the following features: jdbc-data-view, join-data-view, ldap-data-view, ldif-data-view.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWldap-proxy |
Stability Level |
Evolving |
dpconf(1M)
