NAME | Description | Attributes | See Also
Syntax |
dn |
Default value |
none |
Must be set |
No |
Is modifiable |
Yes |
Is multivalued |
No |
Requires restart |
No |
This property defines a DN mapping.
When a client makes a request, the DN is rewritten to match that on the server side. When the result is returned to the client, the DN is changed back to match the client side.
This property takes a Distinguished Name (DN) value.
The default behavior for this property is as follows: No source suffix - do not perform DN mapping
This property is used to configure the following features: jdbc-data-view, join-data-view, ldap-data-view, ldif-data-view.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWldap-proxy |
Stability Level |
Evolving |
dpconf(1M)
