NAME | Description | Attributes | See Also
 Syntax  |
 boolean  |
 Default value  |
 false  |
 Must be set  |
 No  |
 Is modifiable  |
 Yes  |
 Is multivalued  |
 No  |
 Requires restart  |
 No  |
This property specifies whether Server uses "filter-join-rule" and "dn-join-rule" property values stored on join views.
This property is true or false.
This property is used to configure the following features: join-data-view.
 ATTRIBUTE TYPE  |
 ATTRIBUTE VALUE  |
 Availability  |
 SUNWldap-proxy  |
 Stability Level  |
 Evolving  |
dpconf(1M)
