NAME | Description | Attributes | See Also
 Syntax  |
 integer  |
 Default value  |
 unlimited  |
 Must be set  |
 No  |
 Is modifiable  |
 Yes  |
 Is multivalued  |
 No  |
 Requires restart  |
 No  |
This property specifies the maximum number of simultaneous connections from a single client permitted by associated connection handlers.
This property takes an integer.
The value of this property must be at least 1.
The default behavior for this property is as follows: No limit
This property is used to configure the following features: resource-limits-policy.
 ATTRIBUTE TYPE  |
 ATTRIBUTE VALUE  |
 Availability  |
 SUNWldap-proxy  |
 Stability Level  |
 Evolving  |
dpconf(1M)
