NAME | Description | Attributes | See Also
Syntax |
dataSize |
Default value |
unlimited |
Must be set |
No |
Is modifiable |
Yes |
Is multivalued |
No |
Requires restart |
No |
This property specifies the maximum log size in bytes, kilobytes, Megabytes or Gigabytes.
This property is expressed in bytes.
The value of this property must be at least 1M.
This property is used to configure the following features: access-log, error-log.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWldap-proxy |
Stability Level |
Evolving |
dpconf(1M)
