NAME | Description | Attributes | See Also
Syntax |
integer |
Default value |
disabled |
Must be set |
No |
Is modifiable |
Yes |
Is multivalued |
No |
Requires restart |
No |
This property specifies the proportion of modify DN requests that are sent to the attached data source.
This property takes an integer.
The value of this property must be at least 1.
This property can also take the following values:
Do not forward any modify DN requests to the data source
This property is used to configure the following features: attached-ldap-data-source.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWldap-proxy |
Stability Level |
Evolving |
dpconf(1M)
