NAME | Description | Attributes | See Also
Syntax |
duration |
Default value |
120 |
Must be set |
No |
Is modifiable |
Yes |
Is multivalued |
No |
Requires restart |
No |
The availability monitor polls inactive connections to keep them alive. This property specifies how long a connection can be inactive before the availability monitor establishes a dedicated connection to detect the data source.
The duration is expressed in seconds.
The value of this property must be at least 1.
This property is used to configure the following features: ldap-data-source.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWldap-proxy |
Stability Level |
Evolving |
dpconf(1M)
