NAME | Description | Attributes | See Also
 Syntax  |
 string  |
 Default value  |
 all  |
 Must be set  |
 No  |
 Is modifiable  |
 Yes  |
 Is multivalued  |
 No  |
 Requires restart  |
 No  |
This property specifies a pattern for a regular expression. The target DN of a request must match this pattern in order for the data view to handle the request. The pattern is relative to the base DN of the data view.
The default behavior for this property is as follows: Match all operation target DNs
This property is used to configure the following features: jdbc-data-view, join-data-view, ldap-data-view, ldif-data-view.
 ATTRIBUTE TYPE  |
 ATTRIBUTE VALUE  |
 Availability  |
 SUNWldap-proxy  |
 Stability Level  |
 Evolving  |
dpconf(1M)
