NAME | Description | Attributes | See Also
Syntax |
boolean |
Default value |
true |
Must be set |
No |
Is modifiable |
Yes |
Is multivalued |
No |
Requires restart |
No |
This property is a flag indicating whether or not TCP_NODELAY should be enabled for connections between clients and a listener.
This property is true or false.
This property is used to configure the following features: ldap-data-source, ldap-listener, ldaps-listener.
ATTRIBUTE TYPE |
ATTRIBUTE VALUE |
Availability |
SUNWldap-proxy |
Stability Level |
Evolving |
dpconf(1M)
