Configuring the RIP Topology Example
Configuring the RIP Packet Retransmission Interval and Retry Count
Set the RIP Packet Retransmission Interval and Retry Count
Reset the Retransmission Interval and Retry Count
Configuring the RIP Passive Interface
Enable the RIP Passive Interface
Disable the RIP Passive Interface
Configuring the Default Metric
Managing the auto-summary Option
Disable the auto-summary Option
Enable the auto-summary Option
Configuring Interface-Specific RIP Parameters
Configuring Interface-Specific Authentication
Configuring the RIP Default Route Propagation
Configuring the Version for Receiving RIP Advertisement
Configuring the Summary Address
Configuring the split-horizon Option
SEFOS# configure terminal SEFOS(config)# router rip SEFOS(config-router)# network 10.0.0.1
SEFOS(config-router)# default-metric 10
SEFOS(config-router)# redistribute static SEFOS(config-router)# exit
SEFOS(config)# ip route 50.0.0.0 255.0.0.0 vlan 2 SEFOS(config)# ip route 60.0.0.0 255.0.0.0 vlan 2 SEFOS(config)# ip route 70.0.0.0 255.0.0.0 vlan 2 SEFOS(config)# ip route 80.0.0.0 255.0.0.0 vlan 2 SEFOS(config)# end
SEFOS# show ip rip database 10.0.0.0/8 [1] auto-summary 10.0.0.0/16 [1] directly connected, vlan1 50.0.0.0/8 [11] auto-summary 50.0.0.0/8 [11] via 10.0.0.1, vlan1 60.0.0.0/8 [11] auto-summary 60.0.0.0/8 [11] via 10.0.0.1, vlan1 70.0.0.0/8 [11] auto-summary 70.0.0.0/8 [11] via 10.0.0.1, vlan1 80.0.0.0/8 [11] auto-summary 80.0.0.0/8 [11] via 10.0.0.1, vlan1
Review the IP routing table.
SEFOS# show ip route C 10.0.0.0/16 is directly connected, vlan1 C 30.2.2.0/24 is directly connected, vlan3 R 50.0.0.0/8 [11] via 10.0.0.1 R 60.0.0.0/8 [11] via 10.0.0.1 R 70.0.0.0/8 [11] via 10.0.0.1 R 80.0.0.0/8 [11] via 10.0.0.1
SEFOS# show ip protocols Routing Protocol is rip Vrf default RIP2 security level is Maximum Redistributing : rip, static Output Delay is disabled Retransmission timeout interval is 5 seconds Number of retransmission retries is 36 Default metric is 10 Auto-Summarisation of routes is enabled Routing for Networks : 10.0.0.0 Routing Information Sources : Interface Specific Address Summarization : Trusted Neighors : Interface vlan1 Sending updates every 30 seconds Invalid after 180 seconds Flushed after 120 seconds Send version is 1 2, receive version is 1 2 Authentication type is none Split Horizon with poissoned reverse is enabled Restrcts default route installation Restricts default route origination
SEFOS# show ip rip database 10.0.0.0/8 [1] auto-summary 10.0.0.0/16 [1] directly connected, vlan1 50.0.0.0/8 [10] auto-summary 50.0.0.0/8 [10] redistributed via 0.0.0.0 60.0.0.0/8 [10] auto-summary 60.0.0.0/8 [10] redistributed via 0.0.0.0 70.0.0.0/8 [10] auto-summary 70.0.0.0/8 [10] redistributed via 0.0.0.0 80.0.0.0/8 [10] auto-summary 80.0.0.0/8 [10] redistributed via 0.0.0.0
SEFOS# configure terminal SEFOS(config)# router rip SEFOS(config-router)# no redistribute static SEFOS(config-router)# end
