Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
LA Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
LA Overview
Protocol Description
Configuring LA
LA Topology Example
Configuration Guidelines
Default Settings
Enable Link Aggregation
Configuring Port-Channel Interfaces
Configure Port-Channel Interfaces
Configure the LACP Port Priority
Configure the LACP System Priority
Configure Port Channel Load Balancing
Configure the LACP System Identifier
Configure the LACP Port Identifier
Setting the MTU Value
Set the MTU Value on one or More Ports
Set the MTU Value of the Port Channel
Configure the LACP Wait Time
Configure the LACP Time-Out Value
Display the LACP Status
Interaction Between LA and VLANs
In the following example, all of the ports in both switches are configured to belong to port channel 1. Ports 0/1, 0/2, and 0/3 are part of the LA. You must run all of the commands in this procedure on both switches.
  1. Enable port channeling, and create the port channel (1 in this example).
    SEFOS# configure terminal
    SEFOS(config)# set port-channel enable
    SEFOS(config)# interface port-channel 1
    SEFOS(config-if)# no shutdown
    SEFOS(config-if)# exit
  2. Configure the physical ports, and set the mode for each of the interfaces.
    SEFOS(config)# interface extreme-ethernet 0/1
    SEFOS(config-if)# channel-group 1 mode active
    SEFOS(config)# interface extreme-ethernet 0/2
    SEFOS(config)# interface extreme-ethernet 0/3
    SEFOS(config-if)# end
  3. Review the etherchannel information in both switches to ensure that the channel group settings have been changed.
    The output has been truncated for readability. The output should be the same in both switches.
    SEFOS# show etherchannel 1 detail
    Port State = Up in Bundle
    Channel Group : 1
    Mode : Active
    Pseudo port-channel = Po1
    LACP port-priority  = 128
    LACP Wait-time  = 2 secs
    Port State = Hot standby
    Channel Group : 1
    Mode : Active
    Note - Before configuring the LACP port priority, consider that the extreme-ethernet port, 0/3, is the standby port in switches A and B. The maximum number of ports in the port channel is 2.
  4. On switch A, configure the LACP port priority for port 0/3.
    SEFOS(config-if)# lacp port-priority 20
    The possible range of values is from 0-65535. The lower the value, the more likely that the interface will be used for LACP transmission.
  5. Type the show command to review the etherchannel information to ensure that the port 0/3 information was added to the etherchannel report.
    After you configure the LACP port priority, port 0/2 is the standby port in both switches.
