| Skip Navigation Links | |
| Exit Print View | |
Sun Ethernet Fabric Operating System IPv6 Administration Guide |
Route Redistribution Topology in IPv6
Completing Preliminary Configurations
Configure an IPv4 Address for an Interface
Configuring the Basic IPv6 Topology
Configuring the Route Redistribution Topology
Configuring IPv6 Support in an Interface
Add IPv6 Addresses to an Interface
Remove IPv6 Addresses From an Interface
Configuring IPv6 Static Routes
Configuring Static Neighbor Cache Entries
Checking a Local or Remote Endpoint
Check an Endpoint Using Default Values
Check an Endpoint Using the Link-Local Address
Configuring Router Advertisement Parameters
Configure Router Advertisement Parameters
Setting the MTU for Use in PMTU Discovery
Set the MTU for Use in PMTU Discovery
Configuring the IPv6 Route Redistribution Policy for Routing Protocols
Configure the IPv6 Route Resitribution Policy for Routing Protocols
This illustration depicts a basic Oracle's SEFOS IPv6 topology that is referenced in this guide. In this topology, two switches (switch 1 and switch 2) are connected to each other over port 0/3 (P3). Host A and host B are connected through port 0/1 to their respective switches. Finally, three VLANs are enabled. VLAN 3 connects the two switches, and VLAN 1 and VLAN 2 connect the hosts to the switches.
The following table lists the IPv4 and IPv6 addresses of the interfaces and hosts shown in the example topology.
