This section assumes you are using either Solstice Site Manager or Solstice Domain Manager as your management platform. In the following instructions, the term SNM refers to either Solstice Site Manager or Solstice Domain Manager.
The Solaris Bandwidth Manager SNMP agent is compatible with the Solstice Enterprise Agents. To integrate them:
Copy the files ba.rsrc, ba.reg and ba_read.acl to the /etc/snmp/conf directory.
Edit the file /etc/snmp/conf/ba_read.acl to specify hosts that will have read access to the SNMP agent. By default all hosts have access.
Copy the files SnmpAgent.html and qm_snmp.zip to the /opt/SUNWconn/ba/html/beans directory.
Edit the file /opt/SUNWconn/ba/snmp/ba_trap.acl to specify trap destinations. This file must also contain the local hostname, in order to give the SNMP Master Agent read access to the subagent. Specify the trap destinations as a comma-separated list of hostnames, as follows:
trap-recipients = { host1, host2, host3 }
Stop and restart the Solaris Bandwidth Manager agent and then the SNMP master agent.
