Viewing Online Documentation Using the AnswerBook2 System
Defining Your Personal Library
An AnswerBook2 server might contain a large number of collections, each of which contains several books. You can choose whether or not to view all of the collections on the server, based on the settings in your Personal Library Preferences.
The Personal Library Preferences page lists the Complete Library (all collections) available on the current documentation server. To add collections to your Personal Library, click on the checkbox next to the collections you want displayed, then click Save Changes. The change appears immediately on your library page.
You need to redefine your Personal Library if you:
Documentation server names are interpreted literally. For example, imaserver.eng.sun.com is considered to be a different server from imaserver.
Note -
The Personal Library Preferences function is available only if your browser supports cookies and you have not turned off cookie support. Personal Library Preferences expire after approximately one year and must be reset.
