To add an administrative user, select Add Administrator from the Admin GUI. To add the administrative user:
Type the administrator's login ID in the Administrator ID field.
The login ID does not have to match the user's system login ID; it is solely a login ID for performing document-related administrative functions on a specific server.
Type in a password for the administrator.
This password is stored in an AnswerBook2 password database. It does not have to match the user's system password.
You need to enter the password twice for verification.
You can also use the following command to perform this function:
% /usr/lib/ab2/bin/ab2admin -o add_admin -u admin-id [-m server_name] [-p server_port] |
