Port numbers below 1024 are reserved for system use. To use one of these numbers (for example, port number 80) for the AnswerBook2 server, perform the following steps:
Either use the Modify Configuration Settings function in the Admin GUI or edit the /usr/lib/ab2/dweb/data/config/dwhttpd.cfg file and change the following line:
set ServerPort 8888 |
To this:
set ServerPort 80 |
Edit the /usr/lib/ab2/dweb/data/config/nsapi.cfg file and change the following line:
To this:
set ServerPort 80 |
Edit the /etc/init.d/ab2mgr file and change the following line:
su daemon -c "LD_PRELOAD=$pre_load;LANG=$LNG;AB2_ORIG_LANG=$ORGLNG;LD_LIBRARY_PATH=$LD_LIBP;EBT_REGISTRY=$ER;export LD_PRELOAD LD_LIBRARY_PATH LANG AB2_ORIG_LANG LC_ALL EBT_REGISTRY; $AB2BIN/dwhttpd $AB2CFG > /dev/null" |
To this:
su root -c "LD_PRELOAD=$pre_load;LANG=$LNG;AB2_ORIG_LANG=$ORGLNG;LD_LIBRARY_PATH=$LD_LIBP;EBT_REGISTRY=$ER;export LD_PRELOAD LD_LIBRARY_PATH LANG AB2_ORIG_LANG LC_ALL EBT_REGISTRY; $AB2BIN/dwhttpd $AB2CFG > /dev/null" |
This allows the parent dwhttpd process to run as root, which can then use port 80. Note that the child dwhttpd process still runs as daemon.
