When you add an alternate server to the list of servers your server can use, the alternate server is added to the bottom of the server order. This order determines the sequence in which your server accesses alternate servers to follow document links. If a user requests a given document from the library and that document is not available from the default server, the server goes through the alternate server list in the defined sequence to find the document.
To change the order of the servers available to your system, select Modify Server Order from the Admin GUI.
There is no command line option to perform this function.
