Installing and Administering an AnswerBook2 Server
Removing Access for an Administrator
To remove a user from the list of administrative users:
  1. Click on the checkbox next to the administrator's login ID that you want to remove from the List of Administrators.
    This is the administrator's ID, not necessarily the person's system or user ID.
  2. Click on Delete Administrator.
    Note -
    This has no effect on the person's ability to access AnswerBook2 documents as a user. It only removes the person's ability to perform administrative functions.
You can also use the following command to perform this function:
% /usr/lib/ab2/bin/ab2admin -o del_admin -u admin-id [-m server_name] [-p server_port]
