To remove an AnswerBook2 or AnswerBook1 collection from the server's database, select Delete Collection from List from the Admin GUI. To remove the collection:
Select the checkbox next to the title(s) of the collection(s) you want to remove from the Collection List. To deselect a selected item, click the checkbox again.
After you have selected all the collections you want removed, click on Delete Collection.
You can also use the following command to perform this function:
% /usr/lib/ab2/bin/ab2admin -o del_coll -t collection_title |
These functions do not remove the collection packages from the system; they only remove the entry for the collection from the server's database. To remove the packages from the system use the pkgrm utility.
After you remove a collection, you must restart the documentation server. To restart the documentation server, click Restart on the Admin GUI's status page or type the following from the command line:
# /usr/lib/ab2/bin/ab2admin -o restart |
