To view the error log file, select View Log Files from the Admin GUI, then click on View Error Log File. The error log file lists every error that occurred on this documentation server. You can use this information to determine the cause of server problems or unusual behaviors. These errors usually identify the server and port with which the error is associated, as well as some text that describes the error.
You can also use the following command to perform this function:
% /usr/lib/ab2/bin/ab2admin -o view_error [-m server_name] [-p server_port] |
