Solution
After the initial Welcome
screen is presented, the Installation screen is displayed. Perform the following
actions:
Press F2 immediately to verify that the
resolution you want is selected.
Choose the desired resolution, then press Enter.
If you choose a resolution that is above the capabilities of your display
hardware the lower part of the screen is not visible during the installation.
In that case, restart the installation and select a lower resolution.
Use the arrow keys to select Installation, then press Enter.
Only resolution values that are enabled in YaST are available in the screen resolution dialog.
