Java Desktop System Release 2 Troubleshooting Guide
Cannot Eject a CDROM
Problem
Bug ID: 4966284
You cannot eject a CDROM from the CDROM drive. This problem occurs because the fam daemon holds onto the CDROM device so that the file manager cannot unmount the device and eject the CDROM.
Solution
Perform the following steps to eject a CDROM from the CDROM drive:
  1. Log in as root.
  2. Open a terminal window.
  3. Execute the following command: pkill fam
  4. Execute the following command: eject cdrom
