Problem
Bug ID: 4908595
Mounts from /net do not work. This problem occurs because the autofs4 utility loads the wrong kernel module by default
Solution
Perform the following actions when you install the system:
Open the following file with a text editor: /etc/modules.conf
Uncomment the following line:
# alias autofs autofs4
