Change Request Number:
6207091
Systems with two video cards might experience problems
when trying to configure the X server graphics settings. This configuration
is typically done at the end of the installation process. When you configure
the video output, you might see that both of your monitors display the black-and-white
cross-hatching that indicates that an X server is running. However, no subsequent SaX2 configuration program is launched.
If you
reboot your system at this point, the key mappings change to the German locale.
For non-German keyboard users, this might suggest that you cannot login successfully
through the GDM login manager.
