The Yelp browser uses Open Source
Metadata Framework (OMF) files, and a cataloging system.
The XML file for each manual has an associated OMF file. The OMF file
contains information about the manual that is used by the Yelp browser. OMF files have a .omf extension.
When you install an application, the installation process installs an
OMF file to a directory of OMF files. If a Help document has an associated
OMF file in an OMF file directory, users can access the Help document
from the Yelp browser.
OMF files contain information about Help documents such as the following:
The location of the XML file for the Help document
The title of the Help document
A subject category to which the Help document belongs
ScrollKeeper
is a cataloging system for documentation. The Yelp
Help browser uses ScrollKeeper to catalog the manuals
on the system. ScrollKeeper manages the information
in the OMF files for the Yelp Help browser.
ScrollKeeper uses the information in the
OMF files to enable the Yelp Help browser to find
Help documents on a system. When you install an application, the installation
process installs an OMF file to a directory of OMF files.
ScrollKeeper builds a table of contents for
each Help document that has an associated OMF file. ScrollKeeper builds the table of contents from the XML file specified in
the OMF file. The table of contents for the Help document is displayed in
the left pane of the Yelp Help browser window,
and enables users to navigate the Help document in the left pane. The title
of the document in the OMF file is also displayed in the left pane of the Yelp Help browser window.
ScrollKeeper contains a hierarchy of subject
categories to which a Help document can belong. The Help documents are organized
into this hierarchy of subject categories in the left pane of the Yelp Help browser window. The subject category of the document
in the OMF file determines the location of the document in the hierarchy.
The hierarchy of subject categories is defined in the following file:
/usr/share/scrollkeeper/Templates/C/scrollkeeper_cl.xml
The subject category of a document must correspond to a subject category in the following file:
If the Help document XML file is moved to a new location, then you might need to update the location in the OMF file.
