Sun N1 System Manager 1.3 Command Line Reference Manual
set applicationprofile
This command changes the configuration of an application profile.
Description
N1 Grid Engine (N1GE) is the only application that can be provisioned with this release of N1 System Manager.
If an N1GE application profile is currently installed and the N1GE master host is one of servers managed by N1 System Manager, you can change only the following attributes: loadcritical, loadwarning, maxpentime, memcritical, and memwarning. If the N1GE master host is not managed by N1 System Manager, then you can change only the proxyhost attribute.
Synopsis
Parameters
N1GE ATTRIBUTES
