Running Banking and Recipient Processes
This chapter provides an overview of banking and recipient processing and discusses how to:
Note. The PeopleSoft system delivers a query that you can run to view the names of all delivered elements designed for Australia. Instructions for running the query are provided in the PeopleSoft Enterprise Global Payroll PeopleBook.
See Also
Understanding How to View Delivered Elements
Click to jump to parent topicUnderstanding Banking and Recipient Processing
The banking process of Global Payroll combines payroll data, pay entity source bank data, and payee or recipient bank data. The EFT file creation process extracts data compiled by the banking process according to the type of EFT file that you are creating, merges it with data provided by the Australian country extension, and creates the file for transmission.
Note. In this chapter, the payee of group tax is the Australian Tax Office (ATO). The ATO is a recipient just as a health fund or the beneficiary of a garnishment is a recipient. Unless otherwise stated, the term recipient includes the ATO.
Click to jump to parent topicSetting Up Additional Deduction Recipient Information
To set up additional deduction recipient information, use the Deduction Recipients AUS (GPAU_RECIPIENT) component.
You set up your deduction recipients using the Deduction Recipients page (select Set Up HRMS, Product Related, Global Payroll & Absence Mgmt, Banking, Deduction Recipients). You can then add membership ID information about those recipients on the Deduction Recipients AUS page, if needed.
Note. Use the Deduction Recipients AUS page only if you need to attach membership information to deduction elements. Otherwise, use the generic Add Deduction Recipients page.
Click to jump to top of pageClick to jump to parent topicPages Used to Set Up Additional Deduction Recipient Information
Page Name
Definition Name
Navigation
Usage
Add Deduction Recipients AUS
GPAU_RCPPYE_EXT
Global Payroll & Absence Mgmt, Payee Data, Net Pay / Recipient Elections, Add Deduction Recipients AUS, Add Deduction Recipients AUS
Link a payee to a deduction recipient and enter the payee's membership number with that recipient.
Deduction Recipient
GPAU_RCPPYE_SUPER
Click the Super Reporting link on the Add Deduction Recipients AUS page.
Enter Super Reporting details for the payee.
GPAU_RECIPIENT_EXT
Set Up HRMS, Product Related, Global Payroll & Absence Mgmt, Banking, Deduction Recipients AUS, Add Deduction Recipients AUS
Enter Australia-specific additional information about recipients that are set up in the core application for Global Payroll.
SuperEC Detail
GPAU_RECIPNT_SPREC
Click the SuperEC link on the Deduction Recipients AUS page.
Enter receiver, target fund, and sender information according to SuperEC standards.
Click to jump to top of pageClick to jump to parent topicAdding Additional Recipients
Access the Add Deduction Recipients AUS page (Global Payroll & Absence Mgmt, Payee Data, Net Pay / Recipient Elections, Add Deduction Recipients AUS, Add Deduction Recipients AUS).
Recipient ID
Identifier for the recipient of the deduction element.
Membership ID
Membership ID associated with the recipient ID.
Element Name
Name of the deduction element.
Click to jump to top of pageClick to jump to parent topicEntering Additional Recipient Information
Access the Deduction Recipients page (Set Up HRMS, Product Related, Global Payroll & Absence Mgmt, Banking, Deduction Recipients AUS, Add Deduction Recipients AUS).
Group Tax Recipient
Select if the recipient is the ATO, the recipient of group tax.
File Layout
Select the appropriate file layout from those that you have created in Application Designer for report files that you submit to recipients. When you run the Recipient File - Electronic report, the Application Engine process uses the file layout that you enter here.
Note. The GPAU_RCPFILE Application Engine process uses only the GPAU_RCPNT FILE recipient schedule file. You can make minor changes to that file—for example, field order. However, if you make major file layout changes, you must create additional Application Engine programs to process them.
Pay Entity
Enter the pay entity that receives this commission. If the commission is deducted from the payment due to the recipient, the debit to the pay entity's source bank account is reduced by the commission amount.
Calculate Optn (calculate option)
Select from the following values:
Ded Comm (deduct commission): The system deducts the commission amount from the payment due to the recipient.
Rpt Only (report only): The system reports the commission amount in the EFT file but does not deduct it from the payment.
Type
Select Flat Amt (flat amount) or Percentage.
Amount
Enter the flat amount or percentage to be calculated.
Group Number
Enter the unique identifier that the recipient has supplied for the pay entity. For payment to recipients excluding the group tax recipient and payee level recipients, the group number is part of the unique lodgment reference that is part of each recipient EFT file.
Note. The lodgment reference for net pay is the employee ID plus payment date. For recipient payments, it is the group number plus payment date. For group tax payments, it is the EFT code plus payment date.
Super Reporting
Super Fund Administrator
Select to designate the recipient as a Super Fund administrator.
Super EC
Click to access the SuperEC Detail page.
Super Reporting Format
Select a reporting format. Valid values are Agest, ComSuper, and SuperEC.
ComSuper Agency ID
Enter the ComSuper agency ID.
Click to jump to parent topicManaging Electronic Fund Transfers
The Australian standard Cemtex file for EFT is created by a process that provides multiple options to control the file's content. You can create an EFT file that contains:
The following diagram shows the tables that contribute data to the Cemtex file that is incorporated into the EFT file.
Tables that contribute to the Cemtex file
Note. You must finalize the Banking process (GP_PMT_PREPARE) before you can create the Cemtex file. After the Cemtex file is created, the system changes the PMT_STATUS field in the GP_PAYMENT table from P (prepared) to T (transferred).
Click to jump to top of pageClick to jump to parent topicPage Used to Manage Electronic Fund Transfers
Page Name
Definition Name
Navigation
Usage
Fund Transfer - Electronic
GPAU_EFT_CMX
Global Payroll & Absence Mgmt, Payment Processing, Create EFT Payment File AUS, Create EFT Payment File AUS
Enter the parameters for the electronic file creation.
Click to jump to top of pageClick to jump to parent topicGenerating the EFT Code
The system enters the pay entity's EFT code in the header of group tax EFTs as part of the lodgment reference. (The payment date makes each lodgment reference unique to a particular EFT file.)
The pay entity's EFT code is calculated by the system from your ABN, ABN branch, and ATO office code when you enter that information on the Pay Entities AUS page (select Set Up HRMS, Product Related, Global Payroll & Absence Mgmt, Framework, Organizational, Pay Entities AUS). After it is calculated, the system displays it on that page. You cannot change the EFT code directly, but the system recalculates and displays it again if you change the ABN, branch, or office code.
Click to jump to top of pageClick to jump to parent topicCreating the EFT Cemtex File
Access the Fund Transfer - Electronic page (Global Payroll & Absence Mgmt, Payment Processing, Create EFT Payment File AUS, Create EFT Payment File AUS).
The GPAU_EFT_CMX Application Engine process extracts the salary data from the Payroll Results table and creates the Cemtex file for transmission to the bank. You can create files for net pay only, recipients only, both net pay and recipients, or for specific deductions.
Payment Type
Select from Group Tax, Net Pay And Recipient, Net Pay Distribution Only, and Recipient Deduction Only. The EFT file that the system creates contains only payments of the type specified.
Entry Description
Included in the header of the EFT file, this indicates the type of data in the file; for example, payroll.
Calendar Group ID
Enter the ID for the calendar group for which the file is created.
Stream Number
You can create the EFT file for only the payees in the stream that you enter here. Stream processing is applicable to only Net Pay Distribution Only, Net Pay, and Recipient.
Process Streams
This check box is automatically selected if you select the Perform Stream Processing option on the Calendar Group ID page. It indicates that you must select a stream number.
Payment Date
This is the date of the actual transfer of the funds. It is written to the EFT file header.
Debit Date
The system extracts recipient payments where their deposit schedule date is equal to the deposit date. If the recipient does not have a deposit schedule, their debit date is equal to the day that the Banking process was run.
Period End Date
This is the end date for the pay period.
Recipient Calculate Option
Select All Recipients, Deduction, or Select Recipient Only.Select a single deduction or a single recipient ID for the second and third options, respectively. For group tax, the recipient is KAATO, the Australian Tax Office.
Note. You do not have to select anything here for the Net Pay Distribution Only option.
Note. If the GPAU_EFT_CMX Application Engine process returns No Success due to the error "Credit and Debit Transactions Sharing the same Bank Account : 1," the file is still generated. The system transfers monies to the source account in the instance that an employee does not have a valid account due to effective dates or inactivity. The user can then run the file again or send the file knowing that the monies will be returned to the source bank.
Click to jump to parent topicGenerating Recipient Payment Report Files
It is common for organizations to transmit a file to a recipient so that they can update their records. For example, an organization may pay a recipient weekly and at the end of the month deliver a file with all the payment details. Recipients generally specify the information that they want and the report file layout. After you have created the file layout, link it to the recipient on the Deduction Recipients page (select Set Up HRMS, Product Related, Global Payroll & Absence Mgmt, Banking, Deduction Recipients AUS).
The PeopleSoft system provides the GPAU_RCPNT_FILE sample file layout. The GPAU_RCPFILE process retrieves the file layout that is specified on the Deduction Recipients page. The following graphic illustrates a screen capture of a sample recipient file layout
Note. This electronic file depends on first running the GPAU_EFT_CMX Application Engine process for recipients.
Click to jump to top of pageClick to jump to parent topicPage Used to Generate Recipient Payment Report Files
Page Name
Definition Name
Navigation
Usage
GPAU_RUNCTL_RCP_FL
Global Payroll & Absence Mgmt, Payment Processing, Create Recipient File AUS, Create Recipient File AUS
Enter the parameters for generating recipient payment files.
Click to jump to top of pageClick to jump to parent topicCreating the Recipient Payment Report File
Access the Recipient File - Electronic page (Global Payroll & Absence Mgmt, Payment Processing, Create Recipient File AUS, Create Recipient File AUS).
Debit Date
The system extracts payment data for the deposit date that you enter here.
Payment Date
This is the date, from the EFT file header, that the bank passed the payment to the recipient. It's written to the output report file.
Calculate Option
These are the same options as for the EFT creation process: All Recipients, Deduction, and Select Recipients Only.
Select a single deduction or a recipient ID for the second and third options, respectively.
Note. The GPAUPY52 recipient file report is a Structure Query Report (SQR) version of the data extracted for the electronic recipient file. When you run the Recipient File Creation Application Engine process from the Process Scheduler Request page, you automatically generate the SQR. If you want the SQR only, you can select its check box and leave the Application Engine check box deselected.
Click to jump to top of pageClick to jump to parent topicReporting Net Payment
The Net Payment report extracts data from the Cemtex Transaction table and the Header table and from the Personal Data and Job records.
Select detail or summary reporting.
Detail Reporting
The following table shows sample results of detail reporting:
Empl ID
Empl Rcd#
Name
Amount
Payment Method
Bank Name
BSB Number
Account Number
Payment Status
KA0001
0
Taylor, Jane Elizabeth
2976.65
Bank Transfer
ANZ
012002
152545689
Finalized
KA0002
0
Kerr, Elizabeth
4298.16
Bank Transfer
IMB
641800
765908765
Finalized
Total Amount
7274.81
Number of Pays
2
Summary Reporting
The following table shows the same data reported at the summary level:
Total Amount
7274.81
Number of Pays
2
See Also
Global Payroll for Australia Reports
