| Skip Navigation Links | |
| Exit Print View | |
Sun Server X2-4 (formerly Sun Fire X4470 M2) Installation Guide for Linux Operating Systems |
Part I Linux Software Installation on x86 Servers
1. Assisted OS Installation With Oracle Hardware Installation Assistant
Oracle Hardware Installation Assistant Task Overview
How to Obtain Oracle Hardware Installation Assistant
Oracle Hardware Installation Assistant Documentation Resources
Supported Linux Operating Systems
Linux Installation Prerequisites
Linux Installation Task Overview
Oracle Unbreakable Enterprise Kernel for Linux
Installing Oracle Linux 5 Using Local or Remote Media
Installing Oracle Linux 5 Using a PXE Network Environment
Oracle Linux Post Installation Tasks
Installing Oracle Unbreakable Enterprise Kernel for Linux Using Local or Remote Console
4. Installing SUSE Linux Enterprise Server
Installing SLES 11 SP1 Using Local or Remote Media
Installing SLES 11 SP1 Using a PXE Network Environment
5. Installing Red Hat Enterprise Linux
Installing RHEL 5.5 or 6.0 Using Local or Remote Media
Installing RHEL 5.5 or 6.0 Using a PXE Network Environment
Installing the Oracle Unbreakable Enterprise Kernel for Linux
6. Getting Server Firmware and Software
Firmware and Software Access Options
Available Software Release Packages
Accessing Firmware and Software
Part II Linux System Administrator References
A. Supported Installation Methods
B. Supported Operating Systems
Verification of BIOS Factory Defaults
