| Skip Navigation Links | |
| Exit Print View | |
Installing Additional Components for Oracle Java CAPS 6.3 Java CAPS Documentation |
Installing Additional Components for Java CAPS 6.3
Overview of the Installation Process
Installing Additional Repository-Based Java CAPS Components
To Upload Additional Repository-Based Java CAPS Components to the Repository
To Install Repository-Based Java CAPS Components to the NetBeans IDE
To Download and Expand ZIP Files Using the Java CAPS Uploader
To Install Java CAPS Plugins Using the Enterprise Manager Web Applications Manager
This topic provides instructions on how to install additional Java CAPS and non-Java CAPS JBI-based components after the initial installation. It assumes that you have successfully installed Java CAPS, GlassFish , and the NetBeans IDE.
All the JBI-based components of Java CAPS are installed with the initial installation. If you uninstall any of these components, you can easily reinstall them
Note - The following procedure describes how to install these components using NetBeans. For instructions on using a command line or the GlassFish Admin Console, see Installing Java CAPS JBI Components on a New Domain in Installing Oracle Java CAPS Domains and Runtime Components.
encoderlib.jar
wsdlextlib.jar
bpelserviceengine.jar
etlserviceengine.jar
iepserviceengine.jar
pojose.jar
worklistmanagerse.jar
xsltserviceengine.jar
The Installation Configuration window appears.
databasebc.jar
emailbc.jar
filebc.jar
ftpbc.jar
hl7bc.jar
httpbc.jar
jmsbc.jar
ldapbc.jar
rest.jar
schedulerbc.jar
You are now ready to continue using Java CAPS.
