The Entry Cache Monitor Provider exposes monitor information about the state of Directory Server entry caches.
The Entry Cache Monitor Provider component inherits from the Monitor Provider
A description of each property follows.
Basic Properties: | Advanced Properties: |
↓ enabled | ↓ java-class |
Description | Indicates whether the Monitor Provider is enabled for use. |
Default Value | None |
Allowed Values | true false |
Multi-valued | No |
Required | Yes |
Admin Action Required | None |
Advanced Property | No |
Read-only | No |
Description | Specifies the fully-qualified name of the Java class that provides the Entry Cache Monitor Provider implementation. |
Default Value | org.opends.server.monitors.EntryCacheMonitorProvider |
Allowed Values | A java class that implements or extends the class(es) : org.opends.server.api.MonitorProvider |
Multi-valued | No |
Required | Yes |
Advanced Property | Yes |
Read-only | No |
