The Entry DN Virtual Attribute generates the entryDN operational attribute in directory entries, which contains a normalized form of the entry's DN.
This attribute is defined in the draft-zeilenga-ldap-entrydn Internet Draft and contains the DN of the entry in which it is contained. This component provides the ability to use search filters containing the entry's DN.
The Entry DN Virtual Attribute component inherits from the Virtual Attribute
A description of each property follows.
Basic Properties: | Advanced Properties: |
↓ attribute-type | ↓ conflict-behavior |
↓ base-dn | ↓ java-class |
↓ enabled | |
↓ filter | |
↓ group-dn |
Description | Specifies the attribute type for the attribute whose values are to be dynamically assigned by the virtual attribute. |
Default Value | entryDN |
Allowed Values | The name of an attribute type defined in the server schema. |
Multi-valued | No |
Required | Yes |
Admin Action Required | None |
Advanced Property | No |
Read-only | No |
Description | Specifies the base DNs for the branches containing entries that are eligible to use this virtual attribute. If no values are given, then the server generates virtual attributes anywhere in the server. |
Default Value | The location of the entry in the server is not taken into account when determining whether an entry is eligible to use this virtual attribute. |
Allowed Values | A valid DN. |
Multi-valued | Yes |
Required | No |
Read-only | No |
Description | Indicates whether the Virtual Attribute is enabled for use. |
Default Value | None |
Allowed Values | true false |
Multi-valued | No |
Required | Yes |
Read-only | No |
Description | Specifies the search filters to be applied against entries to determine if the virtual attribute is to be generated for those entries. If no values are given, then any entry is eligible to have the value generated. If one or more filters are specified, then only entries that match at least one of those filters are allowed to have the virtual attribute. |
Default Value | (objectClass=*) |
Allowed Values | Any valid search filter string. |
Required | No |
Read-only | No |
Description | Specifies the DNs of the groups whose members can be eligible to use this virtual attribute. If no values are given, then group membership is not taken into account when generating the virtual attribute. If one or more group DNs are specified, then only members of those groups are allowed to have the virtual attribute. |
Default Value | Group membership is not taken into account when determining whether an entry is eligible to use this virtual attribute. |
Required | No |
Read-only | No |
Description | Specifies the behavior that the server is to exhibit for entries that already contain one or more real values for the associated attribute. |
Default Value | virtual-overrides-real |
Allowed Values | merge-real-and-virtual - Indicates that the virtual attribute provider is to preserve any real values contained in the entry and merge them with the set of generated virtual values so that both the real and virtual values are used. real-overrides-virtual - Indicates that any real values contained in the entry are preserved and used, and virtual values are not generated. virtual-overrides-real - Indicates that the virtual attribute provider suppresses any real values contained in the entry and generates virtual values and uses them. |
Multi-valued | No |
Required | No |
Advanced Property | Yes |
Read-only | No |
Description | Specifies the fully-qualified name of the virtual attribute provider class that generates the attribute values. |
Default Value | org.opends.server.extensions.EntryDNVirtualAttributeProvider |
Allowed Values | A java class that implements or extends the class(es) : org.opends.server.api.VirtualAttributeProvider |
Multi-valued | No |
Required | Yes |
Admin Action Required | The Entry DN Virtual Attribute must be disabled and re-enabled for changes to this setting to take effect |
Read-only | No |
