Configuration Reference Home
Oracle Unified Directory - Entry UUID Virtual Attribute
The Entry UUID Virtual Attribute ensures that all entries contained in private backends have values for the entryUUID operational attribute.
The entryUUID values are generated based on a normalized representation of the entry's DN, which does not cause a consistency problem because Oracle Unified Directory does not allow modify DN operations to be performed in private backends.
Parent Component
The Entry UUID Virtual Attribute component inherits from the Virtual Attribute
Properties
A description of each property follows.
Basic Properties: Advanced Properties:
↓ attribute-type ↓ conflict-behavior
↓ base-dn ↓ java-class
↓ enabled
↓ filter
↓ group-dn
Basic Properties
attribute-type
Description
Specifies the attribute type for the attribute whose values are to be dynamically assigned by the virtual attribute.
Default Value
entryUUID
Allowed Values
The name of an attribute type defined in the server schema.
Multi-valued
No
Required
Yes
Admin Action Required
None
Advanced Property
No
Read-only
No
base-dn
Description
Specifies the base DNs for the branches containing entries that are eligible to use this virtual attribute. If no values are given, then the server generates virtual attributes anywhere in the server.
Default Value
The location of the entry in the server is not taken into account when determining whether an entry is eligible to use this virtual attribute.
Allowed Values
A valid DN.
Multi-valued
Yes
Required
No
None
Advanced Property
No
Read-only
No
enabled
Description
Indicates whether the Virtual Attribute is enabled for use.
Default Value
None
Allowed Values
true
false
Multi-valued
No
Required
Yes
None
Advanced Property
No
Read-only
No
filter
Description
Specifies the search filters to be applied against entries to determine if the virtual attribute is to be generated for those entries. If no values are given, then any entry is eligible to have the value generated. If one or more filters are specified, then only entries that match at least one of those filters are allowed to have the virtual attribute.
Default Value
(objectClass=*)
Allowed Values
Any valid search filter string.
Multi-valued
Yes
Required
No
None
Advanced Property
No
Read-only
No
group-dn
Description
Specifies the DNs of the groups whose members can be eligible to use this virtual attribute. If no values are given, then group membership is not taken into account when generating the virtual attribute. If one or more group DNs are specified, then only members of those groups are allowed to have the virtual attribute.
Default Value
Group membership is not taken into account when determining whether an entry is eligible to use this virtual attribute.
Allowed Values
A valid DN.
Multi-valued
Yes
Required
No
None
Advanced Property
No
Read-only
No
Advanced Properties
conflict-behavior
Description
Specifies the behavior that the server is to exhibit for entries that already contain one or more real values for the associated attribute.
Default Value
real-overrides-virtual
Allowed Values
merge-real-and-virtual - Indicates that the virtual attribute provider is to preserve any real values contained in the entry and merge them with the set of generated virtual values so that both the real and virtual values are used.
real-overrides-virtual - Indicates that any real values contained in the entry are preserved and used, and virtual values are not generated.
virtual-overrides-real - Indicates that the virtual attribute provider suppresses any real values contained in the entry and generates virtual values and uses them.
Multi-valued
No
Required
No
None
Advanced Property
Yes
Read-only
No
java-class
Description
Specifies the fully-qualified name of the virtual attribute provider class that generates the attribute values.
Default Value
org.opends.server.extensions.EntryUUIDVirtualAttributeProvider
Allowed Values
A java class that implements or extends the class(es) :
org.opends.server.api.VirtualAttributeProvider
Multi-valued
No
Required
Yes
The Entry UUID Virtual Attribute must be disabled and re-enabled for changes to this setting to take effect
Advanced Property
Yes
Read-only
No
