The Global Index Catalog Extension provides a mechanism to index attribute values when using the distribution feature.
The Global Index Catalog Extension is the object representing the Global Index Catalog. The Global Index Catalog contains one or more indexes that store all of the values of an Attribute Type and the partitionId from which that value can be retrieved.
The Global Index Catalog Extension component inherits from the Extension
The following components have a direct COMPOSITION relation FROM Global Index Catalog Extensions :
A description of each property follows.
| Basic Properties: | Advanced Properties: |
| ↓ enabled | ↓ java-class |
| Description | Indicates whether the Extension is enabled. |
| Default Value | None |
| Allowed Values | true false |
| Multi-valued | No |
| Required | Yes |
| Admin Action Required | None |
| Advanced Property | No |
| Read-only | No |
| Description | Specifies the fully-qualified name of the Java class that provides the Global Index Catalog Extension implementation. |
| Default Value | com.sun.dps.server.globalindex.GlobalIndexCatalogConfigManager |
| Allowed Values | A java class that implements or extends the class(es) : org.opends.server.api.Extension |
| Multi-valued | No |
| Required | Yes |
| Admin Action Required | The Global Index Catalog Extension must be disabled and re-enabled for changes to this setting to take effect |
| Advanced Property | Yes |
| Read-only | No |
