The Global Index Local Backend Workflow Element exposes the content of a Global Index through a Backend interface.
The Global Index Local Backend Workflow Element provides an LDAP access to a Global Index instance. It must be used in addition to a Global Index Workflow Element object.
The Global Index Local Backend Workflow Element component inherits from the Local Backend Workflow Element
The following components have a direct AGGREGATION relation FROM Global Index Local Backend Workflow Elements :
A description of each property follows.
| Basic Properties: | Advanced Properties: |
| ↓ base-dn | ↓ java-class |
| ↓ enabled | ↓ writability-mode |
| ↓ global-index-catalog |
| Description | Specifies the base DN(s) for the data that the backend handles. A single backend may be responsible for one or more base DNs. Note that no two backends may have the same base DN although one backend may have a base DN that is below a base DN provided by another backend. If any of the base DNs is subordinate to a base DN for another backend, then all base DNs for that backend must be subordinate to that same base DN. |
| Default Value | None |
| Allowed Values | A valid DN. |
| Multi-valued | Yes |
| Required | Yes |
| Admin Action Required | None. No administrative action is required by default although some action may be required on a per-backend basis before the new base DN may be used. |
| Advanced Property | No |
| Read-only | No |
| Description | Indicates whether the Workflow Element is enabled for use in the server. If a Workflow Element is not enabled, then its contents are not accessible when processing operations. |
| Allowed Values | true false |
| Multi-valued | No |
| Required | Yes |
| Admin Action Required | None |
| Read-only | No |
| Description | Identifies the global index extension configured for this backend. |
| Allowed Values | The DN of any Extension. The referenced global index must be enabled. |
| Multi-valued | No |
| Required | Yes |
| Read-only | Yes |
| Description | Specifies the fully-qualified name of the Java class that provides the Global Index Local Backend Workflow Element implementation. |
| Default Value | com.sun.dps.server.workflowelement.globalindex.GlobalIndexLocalBackendWorkflowElement |
| Allowed Values | A java class that implements or extends the class(es) : org.opends.server.workflowelement.WorkflowElement |
| Multi-valued | No |
| Required | Yes |
| Advanced Property | Yes |
| Read-only | No |
| Description | Specifies the behavior that the backend should use when processing write operations. |
| Default Value | enabled |
| Allowed Values | disabled - Causes all write attempts to fail. enabled - Allows write operations to be performed in that backend (if the requested operation is valid, the user has permission to perform the operation, the backend supports that type of write operation, and the global writability-mode property is also enabled). internal-only - Causes external write attempts to fail but allows writes by replication and internal operations. |
| Multi-valued | No |
| Required | Yes |
| Read-only | No |
