Configuration Reference Home
Oracle Unified Directory - JMX Connection Handler
The JMX Connection Handler is used to interact with clients using the Java Management Extensions (JMX) protocol.
Parent Component
The JMX Connection Handler component inherits from the Connection Handler
Relations From this Component
The following components have a direct AGGREGATION relation FROM JMX Connection Handlers :
Properties
A description of each property follows.
Basic Properties: Advanced Properties:
↓ allowed-client ↓ java-class
↓ denied-client
↓ enabled
↓ key-manager-provider
↓ listen-address
↓ listen-port
↓ ssl-cert-nickname
↓ use-ssl
Basic Properties
allowed-client
Description
Specifies a set of host names or address masks that determine the clients that are allowed to establish connections to this Connection Handler. Valid values include a host name, a fully qualified domain name, a domain name, an IP address, or a subnetwork with subnetwork mask.
Default Value
All clients with addresses that do not match an address on the deny list are allowed. If there is no deny list, then all clients are allowed.
Allowed Values
An IP address mask
Multi-valued
Yes
Required
No
Admin Action Required
None. Changes to this property take effect immediately and do not interfere with connections that may have already been established.
Advanced Property
No
Read-only
No
denied-client
Description
Specifies a set of host names or address masks that determine the clients that are not allowed to establish connections to this Connection Handler. Valid values include a host name, a fully qualified domain name, a domain name, an IP address, or a subnetwork with subnetwork mask. If both allowed and denied client masks are defined and a client connection matches one or more masks in both lists, then the connection is denied. If only a denied list is specified, then any client not matching a mask in that list is allowed.
Default Value
If an allow list is specified, then only clients with addresses on the allow list are allowed. Otherwise, all clients are allowed.
Allowed Values
An IP address mask
Multi-valued
Yes
Required
No
Advanced Property
No
Read-only
No
enabled
Description
Indicates whether the Connection Handler is enabled.
Default Value
None
Allowed Values
true
false
Multi-valued
No
Required
Yes
None
Advanced Property
No
Read-only
No
Description
Specifies the name of the key manager that should be used with this JMX Connection Handler .
Default Value
None
Allowed Values
The DN of any Key Manager Provider. The referenced key manager provider must be enabled when the JMX Connection Handler is enabled and configured to use SSL.
Multi-valued
No
Required
No
None. Changes to this property take effect immediately, but only for subsequent attempts to access the key manager provider for associated client connections.
Advanced Property
No
Read-only
No
listen-address
Description
Specifies the address or set of addresses on which this JMX Connection Handler should listen for connections from SNMP clients. Multiple addresses may be provided as separate values for this attribute. If no values are provided, then the JMX Connection Handler listens on all interfaces.
Default Value
0.0.0.0
Allowed Values
An IP address
Multi-valued
Yes
Required
No
Restart the server
Advanced Property
No
Read-only
Yes
listen-port
Description
Specifies the port number on which the JMX Connection Handler will listen for connections from clients. Only a single port number may be provided.
Default Value
None
Allowed Values
An integer value. Lower value is 1. Upper value is 65535 .
Multi-valued
No
Required
Yes
The JMX Connection Handler must be disabled and re-enabled for changes to this setting to take effect
Advanced Property
No
Read-only
No
ssl-cert-nickname
Description
Specifies the nickname (also called the alias) of the certificate that the JMX Connection Handler should use when performing SSL communication. This is only applicable when the JMX Connection Handler is configured to use SSL.
Default Value
Let the server decide.
Allowed Values
A String
Multi-valued
No
Required
No
Advanced Property
No
Read-only
No
use-ssl
Description
Indicates whether the JMX Connection Handler should use SSL. If enabled, the JMX Connection Handler will use SSL to encrypt communication with the clients.
Default Value
false
Allowed Values
true
false
Multi-valued
No
Required
No
Advanced Property
No
Read-only
No
Advanced Properties
java-class
Description
Specifies the fully-qualified name of the Java class that provides the JMX Connection Handler implementation.
Default Value
org.opends.server.protocols.jmx.JmxConnectionHandler
Allowed Values
A java class that implements or extends the class(es) :
org.opends.server.api.ConnectionHandler
Multi-valued
No
Required
Yes
Advanced Property
Yes
Read-only
No
