Configuration Reference Home
Oracle Unified Directory - LDIF Connection Handler
The LDIF Connection Handler is used to process changes in the server using internal operations, where the changes to process are read from an LDIF file.
The connection handler periodically looks for the existence of a new file, processes the changes contained in that file as internal operations, and writes the result to an output file with comments indicating the result of the processing. NOTE: By default LDIF Connection Handler operations are not logged because they are internal operations. If you want to log these operations, allow internal logging in the access log publisher.
Parent Component
The LDIF Connection Handler component inherits from the Connection Handler
Properties
A description of each property follows.
Basic Properties: Advanced Properties:
↓ allowed-client ↓ java-class
↓ denied-client
↓ enabled
↓ ldif-directory
↓ poll-interval
Basic Properties
allowed-client
Description
Specifies a set of host names or address masks that determine the clients that are allowed to establish connections to this Connection Handler. Valid values include a host name, a fully qualified domain name, a domain name, an IP address, or a subnetwork with subnetwork mask.
Default Value
All clients with addresses that do not match an address on the deny list are allowed. If there is no deny list, then all clients are allowed.
Allowed Values
An IP address mask
Multi-valued
Yes
Required
No
Admin Action Required
None. Changes to this property take effect immediately and do not interfere with connections that may have already been established.
Advanced Property
No
Read-only
No
denied-client
Description
Specifies a set of host names or address masks that determine the clients that are not allowed to establish connections to this Connection Handler. Valid values include a host name, a fully qualified domain name, a domain name, an IP address, or a subnetwork with subnetwork mask. If both allowed and denied client masks are defined and a client connection matches one or more masks in both lists, then the connection is denied. If only a denied list is specified, then any client not matching a mask in that list is allowed.
Default Value
If an allow list is specified, then only clients with addresses on the allow list are allowed. Otherwise, all clients are allowed.
Allowed Values
An IP address mask
Multi-valued
Yes
Required
No
Advanced Property
No
Read-only
No
enabled
Description
Indicates whether the Connection Handler is enabled.
Default Value
None
Allowed Values
true
false
Multi-valued
No
Required
Yes
None
Advanced Property
No
Read-only
No
ldif-directory
Description
Specifies the path to the directory in which the LDIF files should be placed.
Default Value
config/auto-process-ldif
Allowed Values
A String
Multi-valued
No
Required
Yes
None
Advanced Property
No
Read-only
No
poll-interval
Description
Specifies how frequently the LDIF connection handler should check the LDIF directory to determine whether a new LDIF file has been added.
Default Value
5 seconds
Allowed Values
A duration Syntax. Lower limit is 1 milliseconds.
Multi-valued
No
Required
Yes
None
Advanced Property
No
Read-only
No
Advanced Properties
java-class
Description
Specifies the fully-qualified name of the Java class that provides the LDIF Connection Handler implementation.
Default Value
org.opends.server.protocols.LDIFConnectionHandler
Allowed Values
A java class that implements or extends the class(es) :
org.opends.server.api.ConnectionHandler
Multi-valued
No
Required
Yes
The LDIF Connection Handler must be disabled and re-enabled for changes to this setting to take effect
Advanced Property
Yes
Read-only
No
