Note: this is an abstract component, that cannot be instantiated.
The Load Balancing Algorithm is an algorithm used by a load balancer workflow element to route a request.
The following Load Balancing Algorithms are available in the server :
These Load Balancing Algorithms inherit from the properties described below.
The following components have a direct COMPOSITION relation FROM Load Balancing Algorithms :
The following components have a direct COMPOSITION relation TO Load Balancing Algorithms :
A description of each property follows.
| Basic Properties: | Advanced Properties: |
| ↓ java-class | None |
| Description | Specifies the fully-qualified name of the Java class that provides the Load Balancing Algorithm implementation. |
| Default Value | None |
| Allowed Values | A java class that implements or extends the class(es) : com.sun.dps.server.workflowelement.loadbalancing.AbstractLoadBalancingAlgorithm |
| Multi-valued | No |
| Required | Yes |
| Admin Action Required | None |
| Advanced Property | No |
| Read-only | No |
