The System Info Monitor Provider can be used to publish information about the system and virtual machine on which the Directory Server is running.
The System Info Monitor Provider component inherits from the Monitor Provider
A description of each property follows.
| Basic Properties: | Advanced Properties: |
| ↓ enabled | ↓ java-class |
| Description | Indicates whether the Monitor Provider is enabled for use. |
| Default Value | None |
| Allowed Values | true false |
| Multi-valued | No |
| Required | Yes |
| Admin Action Required | None |
| Advanced Property | No |
| Read-only | No |
| Description | Specifies the fully-qualified name of the Java class that provides the System Info Monitor Provider implementation. |
| Default Value | org.opends.server.monitors.SystemInfoMonitorProvider |
| Allowed Values | A java class that implements or extends the class(es) : org.opends.server.api.MonitorProvider |
| Multi-valued | No |
| Required | Yes |
| Advanced Property | Yes |
| Read-only | No |
