| Skip Navigation Links | |
| Exit Print View | |
Oracle Solaris Cluster Data Service for Network File System (NFS) Guide Oracle Solaris Cluster 4.0 |
1. Installing and Configuring HA for NFS
Planning the HA for NFS Installation and Configuration
Service Management Facility Restrictions
Loopback File System Restrictions
Installing the HA for NFS Package
How to Install the HA for NFS Package
Registering and Configuring HA for NFS
Setting HA for NFS Extension Properties
Tools for Registering and Configuring HA for NFS
How to Register and Configure HA for NFS (clsetup)
How to Register and Configure HA for NFS (Command Line Interface)
How to Change Share Options on an NFS File System
How to Dynamically Update Shared Paths on an NFS File System
How to Tune HA for NFS Method Timeouts
Configuring SUNW.HAStoragePlus Resource Type
How to Set Up the HAStoragePlus Resource Type for an NFS-Exported ZFS
Tuning the HA for NFS Fault Monitor
Operations of HA for NFS Fault Monitor During a Probe
NFS System Fault Monitoring Process
NFS Resource Fault Monitoring Process
Upgrading the SUNW.nfs Resource Type
Information for Registering the New Resource Type Version
Information for Migrating Existing Instances of the Resource Type
The following table lists the sections that describe the installation and configuration tasks.
Table 1-1 Task Map: Installing and Configuring HA for NFS
