Skip Navigation Links | |
Exit Print View | |
Oracle Solaris Administration: IP Services Oracle Solaris 11 Information Library |
1. Planning the Network Deployment
2. Considerations When Using IPv6 Addresses
3. Configuring an IPv4 Network
4. Enabling IPv6 on the Network
5. Administering a TCP/IP Network
7. Troubleshooting Network Problems
11. Administering the ISC DHCP Service
12. Configuring and Administering the DHCP Client
13. DHCP Commands and Files (Reference)
14. IP Security Architecture (Overview)
16. IP Security Architecture (Reference)
17. Internet Key Exchange (Overview)
19. Internet Key Exchange (Reference)
20. IP Filter in Oracle Solaris (Overview)
Part IV Networking Performance
22. Integrated Load Balancer Overview
23. Configuration of Integrated Load Balancer (Tasks)
24. Virtual Router Redundancy Protocol (Overview)
25. VRRP Configuration (Tasks)
26. Implementing Congestion Control
Part V IP Quality of Service (IPQoS)
27. Introducing IPQoS (Overview)
28. Planning for an IPQoS-Enabled Network (Tasks)
29. Creating the IPQoS Configuration File (Tasks)
30. Starting and Maintaining IPQoS (Tasks)
31. Using Flow Accounting and Statistics Gathering (Tasks)
32. IPQoS in Detail (Reference)
IPQoS Architecture and the Diffserv Model
Using the dscpmk Marker for Forwarding Packets
Using the dlcosmk Marker With VLAN Devices
Using acctadm with the flowacct Module
This section contains full details about the parts of the IPQoS configuration file. The IPQoS boot-time activated policy is stored in the file /etc/inet/ipqosinit.conf. Although you can edit this file, the best practice for a new IPQoS system is to create a configuration file with a different name. Tasks for applying and debugging an IPQoS configuration are in Chapter 29, Creating the IPQoS Configuration File (Tasks).
The syntax of the IPQoS configuration file is shown in Example 32-3. The example uses the following conventions:
computer-style type – Syntactical information that is provided to explain the parts of the configuration file. You do not type any text that appears in computer-style type.
bold type – Literal text that you must type in the IPQoS configuration file. For example, you must always begin the IPQoS configuration file with fmt_version.
italic type – Variable text that you replace with descriptive information about your configuration. For example, you must always replace action-name or module-name with information that pertains to your configuration.
Example 32-3 Syntax of the IPQoS Configuration File
file_format_version ::= fmt_version version action_clause ::= action { name action-name module module-name params-clause | "" cf-clauses } action_name ::= string module_name ::= ipgpc | dlcosmk | dscpmk | tswtclmt | tokenmt | flowacct params_clause ::= params { parameters params-stats | "" } parameters ::= prm-name-value parameters | "" prm_name_value ::= param-name param-value params_stats ::= global-stats boolean cf_clauses ::= class-clause cf-clauses | filter-clause cf-clauses | "" class_clause ::= class { name class-name next_action next-action-name class-stats | "" } class_name ::= string next_action_name ::= string class_stats ::= enable_stats boolean boolean ::= TRUE | FALSE filter_clause ::= filter { name filter-name class class–name parameters } filter_name ::= string
The remaining text describes each major part of the IPQoS configuration file.
You use action statements to invoke the various IPQoS modules that are described in IPQoS Architecture and the Diffserv Model.
When you create the IPQoS configuration file, you must always begin with the version number. Then, you must add the following action statement to invoke the classifier:
fmt_version 1.0 action { module ipgpc name ipgpc.classify }
Follow the classifier action statement with a params clause or a class clause.
Use the following syntax for all other action statements:
Assigns a name to the action.
Identifies the IPQoS module to be invoked, which must be one of the modules in Table 32-5.
Can be parameters for the classifier to process, such as global statistics or the next action to process.
A set of zero or more class clauses or filter clauses
The module definition indicates which module is to process the parameters in the action statement. The IPQoS configuration file can include the following modules.
Table 32-5 IPQoS Modules
You define a class clause for each class of traffic.
Use this syntax to define the remaining classes in the IPQoS configuration:
class { name class-name next_action next-action-name }
To enable statistics collection on a particular class, you must first enable global statistics in the ipgpc.classify action statement. For more information, refer to action Statement.
Use the enable_stats TRUE statement whenever you want to turn on statistics collection for a class. If you do not need to gather statistics for a class, you can specify enable_stats FALSE. Alternatively, you can eliminate the enable_stats statement.
Traffic on an IPQoS-enabled network that you do not specifically define is relegated to the default class.
Filters are made up of selectors that group traffic flows into classes. These selectors specifically define the criteria to be applied to traffic of the class that was created in the class clause. If a packet matches all selectors of the highest-priority filter, the packet is considered to be a member of the filter's class. For a complete list of selectors that you can use with the ipgpc classifier, refer to Table 32-1.
You define filters in the IPQoS configuration file by using a filter clause, which has the following syntax:
filter { name filter-name class class-name parameters (selectors) }
The params clause contains processing instructions for the module that is defined in the action statement. Use the following syntax for the params clause:
In the params clause, you use parameters that are applicable to the module.
The params-stats value in the params clause is either global_stats TRUE or global_stats FALSE. The global_stats TRUE instruction turns on UNIX style statistics for the action statement where global statistics is invoked. You can view the statistics by using the kstat command. You must enable action statement statistics before you can enable per-class statistics.
