Skip Navigation Links | |
Exit Print View | |
man pages section 3: Extended Library Functions, Volume 1 Oracle Solaris 11 Information Library |
CIRCLEQ_HEAD_INITIALIZER(3EXT)
cpc_walk_generic_events_all(3CPC)
cpc_walk_generic_events_pic(3CPC)
ct_dev_status_get_aset(3CONTRACT)
ct_dev_status_get_dev_state(3CONTRACT)
ct_dev_status_get_minor(3CONTRACT)
ct_dev_status_get_noneg(3CONTRACT)
ct_dev_tmpl_clear_noneg(3CONTRACT)
ct_dev_tmpl_get_aset(3CONTRACT)
ct_dev_tmpl_get_minor(3CONTRACT)
ct_dev_tmpl_get_noneg(3CONTRACT)
ct_dev_tmpl_set_aset(3CONTRACT)
ct_dev_tmpl_set_minor(3CONTRACT)
ct_dev_tmpl_set_noneg(3CONTRACT)
ct_event_read_critical(3CONTRACT)
ct_pr_event_get_exitstatus(3CONTRACT)
ct_pr_event_get_gcorefile(3CONTRACT)
ct_pr_event_get_pcorefile(3CONTRACT)
ct_pr_event_get_pid(3CONTRACT)
ct_pr_event_get_ppid(3CONTRACT)
ct_pr_event_get_sender(3CONTRACT)
ct_pr_event_get_senderct(3CONTRACT)
ct_pr_event_get_signal(3CONTRACT)
ct_pr_event_get_zcorefile(3CONTRACT)
ct_pr_status_get_contracts(3CONTRACT)
ct_pr_status_get_fatal(3CONTRACT)
ct_pr_status_get_members(3CONTRACT)
ct_pr_status_get_param(3CONTRACT)
ct_pr_status_get_svc_aux(3CONTRACT)
ct_pr_status_get_svc_creator(3CONTRACT)
ct_pr_status_get_svc_ctid(3CONTRACT)
ct_pr_status_get_svc_fmri(3CONTRACT)
ct_pr_tmpl_get_fatal(3CONTRACT)
ct_pr_tmpl_get_param(3CONTRACT)
ct_pr_tmpl_get_svc_aux(3CONTRACT)
ct_pr_tmpl_get_svc_fmri(3CONTRACT)
ct_pr_tmpl_get_transfer(3CONTRACT)
ct_pr_tmpl_set_fatal(3CONTRACT)
ct_pr_tmpl_set_param(3CONTRACT)
ct_pr_tmpl_set_svc_aux(3CONTRACT)
ct_pr_tmpl_set_svc_fmri(3CONTRACT)
ct_pr_tmpl_set_transfer(3CONTRACT)
ct_status_get_cookie(3CONTRACT)
ct_status_get_critical(3CONTRACT)
ct_status_get_holder(3CONTRACT)
ct_status_get_informative(3CONTRACT)
ct_status_get_nevents(3CONTRACT)
ct_status_get_nevid(3CONTRACT)
ct_status_get_ntime(3CONTRACT)
ct_status_get_qtime(3CONTRACT)
ct_status_get_state(3CONTRACT)
ct_status_get_zoneid(3CONTRACT)
ct_tmpl_get_critical(3CONTRACT)
ct_tmpl_get_informative(3CONTRACT)
ct_tmpl_set_critical(3CONTRACT)
ct_tmpl_set_informative(3CONTRACT)
dat_evd_clear_unwaitable(3DAT)
dat_get_consumer_context(3DAT)
dat_registry_add_provider(3DAT)
dat_registry_list_providers(3DAT)
dat_registry_remove_provider(3DAT)
dat_set_consumer_context(3DAT)
devid_deviceid_to_nmlist(3DEVID)
di_link_next_by_lnode(3DEVINFO)
di_link_next_by_node(3DEVINFO)
di_lnode_private_get(3DEVINFO)
di_lnode_private_set(3DEVINFO)
di_minor_private_get(3DEVINFO)
di_minor_private_set(3DEVINFO)
di_path_client_devfs_path(3DEVINFO)
di_path_client_next_path(3DEVINFO)
di_path_prop_lookup_bytes(3DEVINFO)
di_path_prop_lookup_int64s(3DEVINFO)
di_path_prop_lookup_ints(3DEVINFO)
di_path_prop_lookup_strings(3DEVINFO)
di_path_prop_strings(3DEVINFO)
di_prom_prop_lookup_bytes(3DEVINFO)
di_prom_prop_lookup_ints(3DEVINFO)
di_prom_prop_lookup_strings(3DEVINFO)
di_prop_lookup_bytes(3DEVINFO)
di_prop_lookup_int64(3DEVINFO)
di_prop_lookup_strings(3DEVINFO)
ea_match_object_catalog(3EXACCT)
- libdevinfo path node traversal functions
cc [ flag... ] file... -ldevinfo [ library... ] #include <libdevinfo.h> di_path_t di_path_client_next_path(di_node_t node node, di_path_t path);
di_path_t di_path_phci_next_path(di_node_t node node, di_path_t path);
The handle to a device node in a di_init(3DEVINFO) snapshot. For di_path_client_next_path(), node must be a client device node. For di_path_phci_next_path(), node must be a pHCI device node.
DI_PATH_NIL, or the handle to a path node in a snapshot.
Each path node is an element in a pHCI-client matrix. The matrix is implemented by dual linked lists: one list links path nodes related to a common client head, and the other links path nodes related to a common pHCI head.
The di_path_client_next_path() function is called on a multipathing 'client' device node, where a 'client' is the child of a vHCI device node, and is associated with a specific endpoint device identity (independent of physical paths). If the path argument is NULL, di_path_client_next_path() returns the first path node associated with the client. To walk all path nodes associated with a client, returned di_path_t values are fed back into di_path_client_next_path(), via the path argument, until a null path node is returned. For each path node, di_path_bus_addr(3DEVINFO) returns the pHCI child path node unit-address.
The di_path_phci_next_path() function is called on a multipathing pHCI device node. If the path argument is NULL, di_path_phci_next_path() returns the first path node associated with the pHCI. To walk all path nodes associated with a pHCI, returned di_path_t values are fed back into di_path_phci_next_path(), via the path argument, until a null path node is returned. For each path node, di_path_client_node(3DEVINFO) provides a pointer to the associated client device node.
A device node can be a client device node of one multipathing class and a pHCI device node of another class.
Upon successful completion, a handle to the next path node is returned. Otherwise, DI_PATH_NIL is returned and errno is set to indicate the error.
These functions will fail if:
One or more argument was invalid.
Path node information is not available in the snapshot.
The end of the path node list was reached.
di_init(3DEVINFO), di_path_bus_addr(3DEVINFO), di_path_client_node(3DEVINFO), libdevinfo(3LIB), attributes(5)
